Hi there, having a few problems fitting a shower mixer bar. I have fitted backboard type connectors to a board between the studs. I then wrapped PTFE tape around the threads of the 's-connectors' and screwed them in to backboard elbows. I have screwed then in as far as they can go and they are slightly off 150mm centre to centre. they don't leak. I then put my shower mixer bar on and after a week of no leaks - i wasn't using the shower but the water was turned on - a drip started from where the mixer bar attachs to the larger end of the 's-connectors'. Why would i not use PTFE tape on this connection? The only reason is that the instructions for the shower say to use tape on the 's-connector' to elbow joint but not on the shower to 's-connector' joint. Is there a reason? I think i may have over tightened the shower and ruined the washer in there so i have bought new replacement washers - but was just wondering what would happen if i applied the PTFE tape to this joint too - would it help or hinder?
thanks for any advice...
