I am trying to replace the bathroom pull-cord light switch with a switch outside the bathroom door. (The dimensions of the room have changed & there is nowhere suitable near the door to put a pull-cord on the inside).
I want to replace the switch with a connection box and then run a cable outside the bathroom to the wall-mounted rocker switch.
The bathroom light has one red and one black cable connected, with the earth sheathed off & not connected.
The pull-cord switch is connected to one cable only, with the Black cable and Earth cables intact, and the red cable having been cut with each end connected to a terminal in the switch.
I am assuming that I have a junction box lighting system, given that there is only one cable involved?
I have bought a 20amp 4 terminal connection box for the job. Although I'm not a spark, I am assuming that it is fairly straight forward to connect the new rocker switch?
I have a fair idea of what is involved, but I would like someone to tell me how they would do it, just in case I am wrong.
Thanks.
Thanks.
