Please help, total novice at plumbing:
The cold feed in the bathroom is direct mains. And very powerful.
The hot water in gravity fed. the pressure is rubbish. Its only 0.3 head at the bath taps.
I need to fit a reasonably powerful thermo mixer shower.
So i realise i need a single impellor pump for HW to match high powered cold feed.
But where is best place for the pump? I don't want to pump the hot water into the kitchen or bathroom sink. I only want to pump the HW for the bath/shower mixer. So don't want to fit pump in airing cupboard as it#ll effect HW supplies to all outlets.
Would like to fit near bath taps, even under them. Can the pump be fitted lower than the taps? Will i need Negative pump? Aren't they more expensive than normal pumps? Any advice much appreciated, as really can't afford expensive plumbing labour. Would like to do myself if installation is relatively simple.
