Push Fit Fittings
gas4you said:
Tectite professional or whatever they are called also keep the electrical continuity for bonding.
I very much doubt that. What's the resistance of the joint between the pipe and the fitting after both have become scaled up?
I don't know about this factor, but wouldn't the scale form over the continuity joint rather than between it?, if you get what I mean.
I've tested the new fittings in Plumb with my Megger as I didn't believe the claim at first. it was perfect.
Yes I get what you mean, but it isn't an interference fit between tube and fitting, so at the very least I would expect oxidising.
New fittings? Wouldn't they be all fresh and shiny and new? And what resistance measurement did you get?
I just got full continuity 0, as you say you wouldn't really expect anything else on a new fitting, but it did still surprise me.
I will bear in mind your oxidising comments. I don't use that many of them, just in awkward places such as tight eaves etc for pipe drops where I feel a blow torch is too risky.
Presumably that's zero Ohms, but at what range?
What is going on with this site :eek: I posted the above reply ages ago and Softus questioned it, so how is it now thw latest post :rolleyes:
I am getting a bit fed up with this site crashing when I post a reply and then have to re-post it, or some other error message. Have the site admin not got enough bandwidth with their site hosters to cope with demand etc :eek:
Softus, Tectite Pro are specfically designed to maintain continuity.
Tectite is by far the best push-fit range, although you must check that the merchant gives you 15mm when asked for - the nukmber of times I have been trying to force 15mm copper into a 14mm fitting. :evil: :evil: :evil: :evil:
I personally have no worried about using it on any water system - I have lots on mine at home and both my brother's houses are completely done in it.
However, I still love the look and feel of a neatly soldered bit of pipe work.
That I did not know, so I stand corrected. Apologies to anyone I inadvertently misled.
Me too, and quite unashamedly. However, not every choice of fitting is purely aesthetic.
