- Joined
- 27 Jan 2008
- Messages
- 23,711
- Reaction score
- 2,673
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
You have raised so interesting points. MCB may not mind which way around but RCD does. And any wire between inverter and mains supply would need protecting at both ends which would seem near impossible as with inverter in the loft you would need access into loft to reset. So I would assume cable is of a type not needing protection?
The grid tie inverter is clearly a special beast it has an auto shut down with over or under voltage and a minimum time before reconnect which in theroy should mean if the supply cable is damaged then even with a street full of inverters the voltage will either rise or fall causing the inverters to all disconnect.
But this safety system can also be triggered by high or low load and where firms fit the units on a hired roof space system they are likely to set their units just a little high so neighbours units will drop out first.
There seems to be some debate on maximum size of panels. Some say maximum output as fitted to roof others maximum output in ideal conditions? With a East / West facing roof with two sets of panels it will cut in sooner and cut out latter than on a south facing roof but you would need more panels to reach max output. There are special inverters made for the East / West roof as the voltage of both panels will not be the same.
It would seem you can get generators which connect to the mains in the same way. In the main sterling engines built into the central heating boiler which convert what heat is left into power so get the feed in tariff.
I have also seen some units sold for boats and caravans which supplement the supply so when drawing 2 amp the 4 amp left with 6 amp supply charges battery but when drawing 16 amp the 10 amp is supplemented from the battery. What was unclear was the safety aspect does the supply auto fail when unplugged?
