I would like my pyronix enforcer alarm to set my CCTV recording when I arm the alarm. What can I use on the alarm as an output and has anybody done this?
Go to outputs it will be pg1 and set to arm any ...exit to save , two options get a transistor relay that has a 12v + / 0v / trip connection ...wire the pg1 to trip and the other two to + and - as the output is limited to around 250ma
That’s correct final set any
Just Got round to trying it and i can not get 12v output. So in "Endstation Outputs" i have set PGM to 22(Final set any). Wired the output to PGM1 and COM on the next terminal block Z33, COM,+12V,Z34That’s correct final set any
