Please may someone advise on this fault on my wireless pyronix enforcer. I had low battery warning on the bell box, replaced yesterday and this evening I have the attached fault. Has it lost signal? Any tip to resolve would be greatly appreciated!
Just wanted to ask how simple it is to replace the battery? How to disable tamper first? Is it easy enough to remove the cover? Is it simple case of swap battery and siren continues being paired with the panel or does it lose all settings once the battery is replaced?
