Pyronix V10 input types
17 Jul 2018
Hoping for some support/clarity on input types if possible
Input 1 - Front Door Contact (07 Final Exit) A B C
Input 2 - Living Room PIR (09 ER Area FX) A B C
Input 3 - Upstairs PIR (06 Intruder) A C
Input 4 - Back Door (06 Intruder) A C
Where I'm struggling is whether Input 2 should be 09 as is, or 10 (FX Part ER)?
The Input 2 PIR does not get passed on the route between Panel and Front Door during exit (full set A), but could potentially be passed between Panel and Back Door on Night Set... Currently that activates the entry timer as a reminder the alarm is set before all bells and whistles go off when the back door gets opened... Is that right as is?
What if I want to change the Input 4 from Intruder to Final Exit as well giving us the option to use both doors as an entry/exit route, can that be changed and simply leave Input 2 as is?
Any help understanding Input types 09 and 10 a bit more would be great! :D
09 starts entry exit in part set B C D
10 is the reverse entry in A and alarm / entry route in part
Keeping your entry routes down to a minimum makes your system more secure !
Cheers Sparky that’s what I thought...
So in terms of front and back door both should be 07?
Is the only impact the timer delay before siren goes off or anything else?
Any alternate suggestions / options?
