Quadrant tiles round bath
23 Apr 2007
hi all
Am doing up the bathroom and have got a question for you: i have put in one of those ridiculously overpriced Cristal quadrant trims around the bath, and i have noticed that the gap between these new tiles is quite large - up to 8mm (btw this is the gap between the quadrant tiles, not the gap between the quadrants and normal wall tiles / bath)
What should i use to fill the gap? The quadrant tiles are fixed to the wall tiles / bath with the silicone sealant that came in the pack, but i don't know whether i should use it to go in between or not because the gap is so big! should i use a grout instead?
I have a tube of BAL silicone and a pack of powdered water-resistant grout kicking around somewhere, and would prefer not to have to go shopping again...
Thanks!
Seems strange. I wouldn't mind seeing a photo of that before giving out any advice.
I'm taking it that these quadrants are much smaller than the other tiles? You could have started fitting these quadrant tiles so that they purposly don't line up with the grout joints in the regular tiles. That way you could have kept the gap the same.
weird isn't it - on the quadrants packaging it states they have a "nominal size" of 150 mm width but a "work size" of 147mm.
The wall tiles are 150x150 (with only a 1mm grout line by the way)! so they would have matched up if the quadrants were also 150 instead of 147 - i wanted the quadrants to line up with the wall tiles to keep them neat. No camera i'm afraid, so can't take a piccy!
the largest gap is actually 7mm, which isn't the end of the world. I just don't understand why the quadrant tiles are only made 147 wide. Seems silly to me!
cheers
harry
Well seeing as though you've done it, grout em. I wouldn't silicone them in between. Reckon it would have looked better if you'd had put them on like I said though.
