Question about steps (landing, going and rising)
r_c
19 Jun 2016
I hope someone with more knowledge of this can help me. We need to build some steps to get from the side alley outside to our utility room door. The ground is just under 50cm below the floor of the room. The door opens inwards. The fence is about 1.47m from the door.
Can you please tell me:
  • Is there a minimum length (a) required for the top step? (Is this top step considered a 'landing'?)
  • Am I correct that we will need 2 steps to get up from the outside ground level to the internal room level? If not can you please tell me how many steps you think are needed.
  • Are there any building regulations regarding the space between the fence and the bottom step?
Thank you
A difference in level of less than 60cm is not controlled under Building Regs, so you can dispose the steps however you want.
  • Thanks
Reactions: r_c
....... unless the route or structure or other work associated to use of the access/egress is controlled.
  • Thanks
Reactions: r_c
