I've got a problem with my VCW GB 242 EH being reluctant to fire up (not quite operating the microswitch when DHW is drawn; subject of recent post)
I need to confirm whether the fault really is in the water valve section (diaphram etc) or conceivably the secondary heat exchanger being scaled up, leading to insufficient differential pressure to operate the valve.
I've just measured the DHW flow rate at 10 litres/min whereas the manual states "nominal capacity of domestic water" as 8.7 l/m.
This suggest to me that the heat exchanger is not the problem - Can anyone kindly confirm that my line of thinking is correct ?
