Come on, how is ANYONE going to know without site visit, volume on the sockets and appliances, distances to CU, routes to CU and overall condition of CU, earth bonding etc ??
Is the kitchen tiled (and do you mind them being broken)
What's the route between kitchen and CU (under floor and is there access)
What socket type do you want? White, metal, flat ?
On the assumption that the kitchen is gutted by a.n.other and that plastering and reinstatement of fabric damage will be covered by a.n.other, on the assumption that your Southern based.
8 x sockets- white MK
4 x f/spurs withe neon with appliance outlets below counter- white MK
8 x spot lights- chrome GU10's, existing wiring for switch and circuit feed use able
1 x cooker circuit and cooker isolation with connection below counter / behind oven
1 x hob circuit 6 kw induction
1 x fan- kitchen strength and f/ spur with neon
CU in spec (with RCD) and bonding, earthing and tails, all in spec
Testing and certs, notifiable works.
2 days 1st fix
2 days 2nd fix and testing
1 day survey /material procurement and misc
fittings, cable and components
In the region of..........................
About the price of a nice holiday, two weeks in Florida for two
