- Joined
- 20 Jan 2005
- Messages
- 20
- Reaction score
- 0
- Country
Hope someone can advise. I have 1 towel rail that has three heating sections, only 2/3rds of the first section is hot and the rest is cold. I assumed it had air in it so tried to bleed it through the vent at the top. Air escapes for approx 5 secs then stops. If you undo the actual valve itself (which sits on the top right of the rail) water escapes proving to me ( a plumbing know nothing !) that there is no air to bleed. So why does it not heat up the whole rail. It has worked fully since it was installed and I noticed the change after towels were not drying. I also have 1 radiator that is also behaving in a similar way.
Help or advice would be much appreciated.
