radiator removal
6 Oct 2020
I want to lose one of the rads in our lounge, and make the other bigger. Can I just remove one and cap it off, or are they connected, so if I remove one the other won't work?
Thanks.
Simple way to check - Turn the valve(s) off, on each side of the one you are considering removing. Start the heating, if the remaining one gets hot, you can remove it.
