Radiator with twin entry in 15mm
4 Dec 2004
Wiltshire
This is more in hope than anticipation. Are there any rads avlbl with both entry and exit on one side? The current one is on a 15mm system and has to be moved, and I would like not to have to conceal a pipe in the floor if possible, so entry and exit on one side would help.
TIA
One of the Sterad range has bottom entry on the left side.
Most radiators will come that are not a roll top will come with four holes and you can choose which ones you use for the blank, the bleed point and where you connect the pipework to. Usually centerrad, stelrad etc are like this.
cheers
