Help!! 1 radiator wont work. Turned off all others to force water thru system but no luck. Took off rad and flushed it, turned on valves to see they were working, attached hose from o/side tap to both valves to clear air-lock, replaced rad + still wont work.
However, if I drain about 4 pints from the rad drain off, the hot water comes thru + rad works for 2-3 days.
Took off rad and replaced with length of 15mm pipe and pipe heats up immediately so I assumed the problem was the rad itself.
Bought new rad and installed, and turned on heating. Rad got hot immediately but stopped working after 5 days.
It seems as though the rad won't heat up if I let the system go cold for 2/3 days.
Something must be stopping the rad from heating up but I can't fathom it out and I don't want to keep draining the rad to draw water thru.
Any ideas would be gratefully received!!!!!
