Our radiators have never clanked until this evening. They are the type that don't need to be "bled" and from what the man of the house says, the water flows in at the top and out through the bottom, eliminating air bubbles.
This evening, the radiator by the front door began clanking - loudly. Mr. Man went over to check the heat coming from the radiator and found it was much hotter than usual. The thermostat was set at around 64. The radiators get warm, but never really too hot to touch. Anyway - the entire radiator was hot - very hot. He checked the boiler in the basement and said it appears it needs water. He cut the heat off until he can discover the issue with the clanking and very hot radiator. It's not really that cold here right now (Virginia) - in the high 30's, so it won't kill us not to have heat. Still...it would be nice...
Is this something usual? Have I provided enough information? Do boilers need to have water added? Does it evaporate somehow? BTW - the valves on these radiators don't work - there is no hissing or escaping steam.
Thanks, all, for any info.
