Hi all,
In our downstairs toilet (only about 2sqm) I have just ripped up some old laminate flooring and underlay, revealing a decent condition, albeit with some small lumps and bumps, concrete floor.
The boss has bought some cushioned sheet vinyl that she would like me to fit. I have about a 10mm discrepancy in the floor level that I need to fill between that floor and the hallway.
The toilet is also being replaced, so I've got a blank canvas to work with, so to speak.
Should I...
1) Put down 9mm ply sheet on top of the concrete and lay the vinyl on top of that. Is there an issue with a damp membrane being needed or anything? Also, I can see it could be a pain and quite a lot of effort to drill and screw the number of holes at the correct centres
2) Use self-levelling compound. I've never used this. Do I just mix and throw it down, or do i need to prime beforehand? Could the vinyl sheet then be fixed straight to this using adhesive?
3) Do something else. Is there a better option that I'm missing?
Thanks in advance for any advice.
Should I...
