hi all, party of my raised deck will be over a single strip of paving slabs.
I need to put some posts down, but on the paving slabs do the posts just get attached to the joists and rest on the slab?
hi put a runner on top of yor slabs ie3x2 or 4x2 then come off that with your 8x2 s or 6x2 s @ 90 degrees you might have to cut a joint out of your runners to fit onto the one on top of your slabs hope thats not as clear as mud
If the base is tsable then the posts that the deck is supported on (assuming its at ground level) sit on the base. They do not need to be fixed to the base in anyway due to the weight of the deck.
