- Joined
- 19 Jan 2005
- Messages
- 1,171
- Reaction score
- 41
- Country
Hi all - need to pick your collective brains!
My RCD has tripped twice in 2 days - so a fault I think!
The CCU is less than a year old, tested out fine and everthing except lighting circuits are on the RCD side. This is the first time I have had a problem.
Nothing about the load has changed and so far I can't see a common element to what was on when it tripped. It resets OK and no MCB's have operated.
I have been having some work done in the bathroom and this has an electric plump, so would testing out the cable to it be the first port of call?
As I understand it the RCD detects an imbalance of current in the phase and neutral (ie it must be in the cpc) of more than 30 mA. So is this more likely to be a damaged cable than a faulty appliance?
If it's not the pump, how do I go about sussing out where the problem is - esp as it is so intermittant?
Hope you can help!
SB![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Hope you can help!
SB
