evening all, i have recently installed a new dual rcd consumer unit at my house. the old cu had cartridge fuses, one was a 5 amp for lighting upstairs and down stairs one 30 amp for sockets and one for cooker.
i separated the 2 feeds for the lighting and connected on opposing rcd sides. one which for downstairs lighting and the other for upstairs.
my problem is that the landing light operating via a 2 way switch bottom and top of stairs will trip the rcd when switched. even if the mcb on that circuit is off it will trip, and when i use the top switch both rcds will trip.
stupidly i may of nipped one of the cables as i used a cable as a draw to bring in the new kitchen ring that i wanted concealed behind the wall instead of in trunking down to cu. or could it be that the 2 lighting cables should not of been separated. as you'll see on a previous post about a single black becoming live when switched this is wired in singles.
any suggestions welcomed.
