Re-pressurising Baxi Duo-tec Combi
13 Feb 2011
Manchester
Please can someone help! I have E119 error which I have read that means I need to re-pressurise the bolier. I have opened the values - leftside 1st and then opened the right but nothing is happening - any advise?
Gail
You have opened the correct valves? They have a black round knobs on??
They need to be opened quite a bit.
open righthand valve Fully then open l/hand slowly till pressure starts to rise.
If they are fully open it may be that the nrv is stuck in which case best advise would be to replace with a standard filling loop.
U may need a plumber for this.
Thank you, yes I am opening the values with the black ends.
Will try the right and then the left.
No opening the right and then the left didn't work - any other suggestions on a Sunday night :confused:
Iv have had a few of these that have broken and the non reuturn valve has come away blocking the inlet, try slackening the middle (copper\) section then opening the the left valve and see if any water escapes.
The baxi filling loop is the worst part of what i consider to be a good boiler.
UNless u take the left hand valve off the boiler and prise the nrv out theres nothing really that u can do.
Its also likly that if u remove it without replacement washers or sealing compound u will end up with a leeking boiler.
Replace with std filling loop and it wont bother u again.
A good plumber shouldnt take more than an hour plus parts (tenner)
The power being on will not damage the boiler they have a low pressure switch inside which stops the boiler working to protect it when this happens
What caused the drop in pressure. Have you bled any radiators?
