Re-routing central heating - is this a valve?
25 Oct 2008
Cheshire
I'm in the process of renovating my kitchen and will need to re-route some pipe work from the combi boiler.
However, it seems to have a valve or something in the bit I need to shorten.
It was hidden behind the old wall cupboard and seems to be leaking slightly at the screw.
The pipe seems old, and smaller than the standard 22mm, so guessing I need a modern equivalent to this fitting?
It's new 22mm copper pipe coming out the combi and into this older pipework.
Looks like an old non-return valve from a previous gravity system. Best remove it and solder new pipe section. You can buy imperial to metric couplings if it is 3/4" pipe.
Looks like an old non return valve probably from an earlier system,u can probably cut it out if it's just a Combi system an get a straight adaptor from 22mm to old three quarter pipe
Thanks both.
Was hoping it was a hangover from the old system. Will remove as you suggest.
Combi in bedroom above, comes down wall, across part of kitchen floor and back up into bedroom above, in a big U shape.
Would have thought when they changed to combi and took boiler out of kitchen they would have simplified!
