I have recently had a Baxi Netatec combi boiler installed in conjunction with a Baxi 720644701 wired 7 day programmable sensor.
I have programmed the central heating to come on 3 times a day thinking that at the end of each program the heating would go off until the next timed event. Apparently this is not happening and at the end of each timed period the system goes into "Reduced Mode" whereby the boiler still fires up but heats at a reduced rate.
My question is, when I want the heat off I want it off not to go into "Reduced Mode" do you know how to disable this mode? The manual is not very helpful on this. Thanks
