Hi Gents,not used this forum for some time.I have moved in to a house where there is a ferolli DOMI Condens boiler fitted. The boiler is approx 2 years old. The previous owner has drained the system down. How do I refill it again. It also seems there is no air pressure in the vessel. Do I need to pressurise this 1st before filling the system. (14psi) Also is there a vent valve on this boiler.there is a cap at the back of the boiler with a small hole in it but the cap is closed. Also for reference,Is there a drain cock on the boiler. I have read that the vessel may have water in and need to drain the boiler only while repressurising the system.
I would be really grateful as I need to get some heat on.
ps there is no room stat and there is an integral clock,any idea how to set this as the instructions refer to the room stat or the remote control(missing)
Thank you
Thank you
