Hello,
I am having some difficulty with a Yale door lock. I removed it to see if I could fix it. The issue is that the brass part (that goes goes into the door frame) slips forward when the door is left on catch, meaning that if you use the catch with the door closed (while you are outside), you can get yourself locked out.
Anyway, I took the lock apart and have tried to put it together, but I can't see how to put the spring back in.
I have looked elsewhere on the internet and found nothing that helps me.
I have attached a photo to this message. I know that the spring sits on the right side of the photo.
Hopefully someone can help.
Thanks for reading.
View media item 49869
Thanks for reading.
