Remeha Avanta Combi Boiler
4 Jan 2013
Just purchased an isense wireless RF thermostat the instructions say to first change boiler to open therm, (no instructions in manuel to say how to do this) any ideas.
If your boiler does not support OpenTherm SmartPower you will need a separate 5V power supply for the iSense receiver.
all remeha support open therm..its just a question of connecting it to the right terminals on the board removing any existing ones.
Any competent installer can do this...
The boiler was fitted 2 years ago it is an Avanta plus 35c it was fitted with a wireless remeha mechanical thermostat, which the dog chewed. I have disconnected the receiver which was in the boiler front which had 4 wires going into block X2 pins 1,2 3 and 5 and wired the isense into terminal 7 & 8 of block X9 as stated in the manual ibase powered up with green light flashing every 4 secs (instruction manual says working) but when trying to connect to it with isense fault 216 showing saying Unable to connect to ibase. Tried over and over again will not connect. Any ideas.
I would ask the installer back...and if you are an installer get into the combustion chamber!
Thanks, tried resetting many times reset ibase (held it down till it flashes every second) but will not connect to isense
you need to re wire block X2 with 1 to 4 and 3 to 4
then connect i sense rf unit to terminal 7 and 8 as per instructions.
the power for the unit is provided by terminals 7 and 8 these reguire a feed signal form the connections in X2
Ha Ha Agile No not a CORGI but a Bulldog and everytime it moves heating comes on
