I mean after PVA (what does the following C stand for) or PVAC the flooring together to create a more water resistant join, at a later date can I dismantle the flooring (if I move)?
Or will trying to dismantle the floor after it being PVAC destroy the click system?
Assuming the flooring is nailed or glued, then dismantling the flooring to take it to your new home will be no more difficult than removing the wallpaper so you can re-hang it at the new place.
PVAc (the "c" us a small one, apparently) = Poly Vinyl Acetate, or what we mere mortals call PVA..... Must remember to use the correct nomenclature, like PVCu not UPVC.
Even if the floor isn't 'stuck-down' (glued to the underfloor) but only the T&G's are glued, the PVAc wood-glue will have the same effect: when removing the floor the tongue will normally end up broken and stuck in the groove. Remedy: chisel out and glue the boards to the underfloor.
On the other hand: why would you want to 'move' your floor with you? A proper Natural Wooden Floor increases the value of your home, making it an extra sellable feature and the money 'gained' can be invested again in a new Natural Wooden Floor in your new home. That's why we like to call it: a 'Solid' Investment
pva glue soaks into the wood and is in general stronger than wood its self
if its the click system [and NOT glued]you can re use it but your talking 10% waistage because its been cut to fit
another10% because you ruined it taking it up another 10% because it got dammaged in transit ect ect ect
