- Joined
- 13 Mar 2019
- Messages
- 727
- Reaction score
- 176
- Country
Back wall of my house is always cold and tends to get mouldy at the bottom. It's built in to a slope somewhat, the ground level outside is about 5-600mm higher than inside. Pile on the left has come out of the cavity. The DPM is right at the level of the flags, one of which I have taken up:
I've taken out a window board to see what's going on and it's got quite a lot of rubble in [picture isn't too clear but that's about 300mm deep].
That grey stuff with a timber block on it is clear plastic sheeting and it runs down to floor level behind the plasterboard. This is presumably an attempt by a previous owner to fix a damp problem.
A few questions....
- Is there some tool/technique the pro's use for removing rubble from cavities? Tried a 'grabber', it takes 2-3 attempts for each item, painfully slow. Had my son doing this for 5p an item but it was more work supervising him than doing it myself [and was looking like bankrupting me]. I've got a 48" wrecking bar and a Henry. That's been a bit quicker, smash everything until it's small enough for Henry to suck up. Still damn tedious work though. I need a rock-crushing attachment for the Henry.
- How about that earth directly against the exterior leaf? Should there be a DPM between that and the wall, or what? Retrofitting that is going to be pretty tedious and even more laborious.
- The highest point of the rubble in that picture actually seems to be piled on a brick that's been mortared in place, in the cavity. Is this some early form of cavity tie? House was built in the mid 1960s.
A few questions....
