Ive moved a stud wall, and now have radiator pipes in the middle of the room, my plan is to totally remove one of the radiators pipes, by putting a straight run through from the two old valves. The other i plan on moving the valves about 2 foot with new pipe and conceal in the stud wall ready for my towel radiator.
Am i correct in thinking that the above wont cause any problems?
When i drain the system its a combi boiler do i.
Turn power off to boiler,
open drain valve in celler and fit hose to drain
open upstairs rad valves
Drain the system (does this need to be totally?)
Do the work required
Fit towel rad
Fill the system
bleed rads downstairs, then bleed upstairs
Have i missed anything important
Andy
Fit towel rad
Fill the system
Andy
