Removing cavity wall insulation
4 Nov 2009
Blackpool
Anyone got any proven ideas on how to remove cavity wall insulation(rockwool type) cheers Graham :?:
Its a very narrow cavity and the insulation appears to be retaining water.I was hoping someone my have a way to remove other than taking bricks out every few feetThanks for the reply,cheers Graham.
If the insulation is retaining water, then you have a problem with the external brickwork or pointing - or roof.
But how do you know that the insulation is retaining water and what problem is evident?
You need to identify cause and rectify that, rather than trying to deal with the symptoms
