Hi
3 Years ago I bought a bungalow (a corner plot) and at one end there is a gas supply with a meter that when isolated shuts off the gas to the house. My gas engineer has investigated as best he can and it seems this pipe is supplied from the road at that end of the house. At the other end of the house there is another gas pipe that appears to be supplied from another road at that side of the house. The pipe has an isolator and is capped off with no meter. My gas engineer says it is still live. After further investigation it seems that in the distant past the mother inlaw of the owner lived at one end of the house while they lived in the other so i'm assuming this might have been the reason for the two supplies!?!? Anyway i intend to do some work at the end of the house with the redundant supply line and I could really do with getting it isolated incase it is disturbed. I contacted Northern Gas Networks and explained the situation and the safety concerns and they came out and said no bother we'll disconnect it and 4 days later I get a quote for £500.
Can someone tell me if it is normal to be charged to get the gas turned off? From what i can tell they did not have any record of the pipe. They said they would only need to gain access to the house for 10 minutes so i'm assuming they are not removing the pipe only disconnecting it. So what is costing £500 and can I not challenge this amount? In the small print it does suggest i can get another quote off someone else but after following the link (girs.co.uk) i just get lost in the links. I don't think its an option to carry out the work around the pipe as it is.
Thanks in advance for any advise
Shaun
Shaun
