Removing varnish from furniture
14 Dec 2005
Berkshire
My dining table and chairs needs to be re varnished.
They need to be stripped to the bare wood.
What is the best recommended procedure - chemical - sandpaper.
Thanks for your advice
If they are anything other than very straightforward pieces (e.g. carved, etc) then I'd consider getting a stripper to do the job for you. If they are modern pieces they are probably not varnished at all - Nitromors is nasty stuff to deal with and in any case can't shift some of the 2-pack lacquers which have been around since the sixties or seventies. A good stripping shop can get specialised strippers to handle this sort of stuff. Just watch out for different species/tones of wood as modern chairs are frequently made-up from a hotch-potch of different timbers stained to look alike. If they are varnished and the varnish is crazed then scraping may be your best bet followed by a light sanding. Be sure to wear a mask.
Scrit
