- Joined
- 13 Jul 2004
- Messages
- 13
- Reaction score
- 0
- Country
I've finished constructing a block wall with a radius on the boundary of my property. I think I may have boobed on my scratch coat with 5:1 sand cement ratio when it should have been 4:1. Can I get away with a 5:1 finish coat or should I weaken it to 6:1? The wall faces roughly west in the SW of England and is 1m - 1.5 m high
Also I have used a 3 in 1 admixture rather than lime for the first time. Is it safe to continue to use this on the finish coat, or should I use lime instead?
One final question - I have set a s/s bead up on the top edge to act as the top screed For the bottom screed I cut strips from a UPVC facia board and screwed these to the wall, plumbing it from the top screed. Therefore I should be able to create quite a decent curve using my long (1.5m) plastic float. Best will in the world I know it's not going to be perfect, so should I finish with a dry (damp?) sponge?
Thank you for any help or advice.
Mark
Mark
