Repair to external architrave
4 Aug 2020
I am looking to repair the external architrave to my front door. Its my last attempt before ripping out and replacing with a composite (which I would really, rather not do) and im hoping that I can repair, rather than replace the architrave.
I have my wet rott hardner and epoxy exterior wood filler at the ready, but can anyone advise how I can best tackle the curves of the moulding when sanding down?
I have been looking at getting some drum sanding bits for my drill to get into the crevasses, but any tips would be much appreciated. Thanks
C_scottie86, good evening.
Can I be the rain on your ideas, Sorry!
Given the condition of your Architraves [especially image 2] you may be better in totally replacing these architraves?? I think you will be chasing around for a considerable time to achieve a [really] not too good a finish after a lot of work should you attempt a repair on what you are faced with?
There are several WWW. sites where such Victorian "Type" architraves are available, give a bit of research you should be able to locate something that takes your fancy, if possible given the exposure it may be advisable to look @ hardwood?
A couple of such sites are noted below [there are a load more?]
Ken.
https://mdfskirtingworld.co.uk/arch...ave/?msclkid=2d7aae3d804b174ca5dbf11426afa8f6
https://www.wooduchoose.com/wooden/architrave-17/
