replace cisturn valve for cable push rather than air push
24 Apr 2008
UK, Wittering, West Sussex
i have a comfort height cistern on a couple of toilets
may not be this make specifcally - however it looks the same as this
the pneumatic push is proving difficult for my other half pushing fully in to flush
we had a cable verison in an old house which was much easier
can the flush valve - which is quick release be changed to a cable version
I have fitted a lever cistern in our 3rd toilet and i have also spent time modifying one of these comfort systems to raise the toilet and modify the cabinet
so if i have to replace the cistern maybe thats the way to go
of course I have a faceplate, and i suspect the "button" will be a different size , which i suspect a replacement front panel from monroe in the same finish will cost £100
Depends on the flush valve installed. Yes, you’ll need to change the face plate
thanks for the reply, I was hoping someone here may know what will replace the flush valve - theres a few on screwfix - I didnt really want to take it all apart and then look for something - cant find a decent spec online for dimensions, except for the flush pipe into the cistern which is 50mm
looks like i will have to remove and then see what i can find and compare , unfortunatly
