Hello All!
I'm sure this is very basic stuff, however I am a complete novice but think this is one of those jobs I really don't need to pay someone else to do )
The isolation valve on the mains supply to my toilet is leaking, the pipe to the current valve is copper, the valve is then a plastic type with a small tap, the pipe above that that goes into the toilet is plastic.
I was going to get a metal compression type, one of these:
http://www.screwfix.com/p/isolating-valve-with-handle-15mm/89226
But wondered if this is ok to use when fitting from copper to plastic?
So I then wondered If I should get a plastic one similar to the one that is currently in place, such as this?
http://www.diy.com/nav/fix/plumbing...m-Shut-Off-Valve-Cold-11477870?skuId=11988577
Any advice would be hugely appreciated.
Thanks alot
Thanks alot
