I am fitting a new kitchen, this will allow access to the water main pipe work, this has two stop cocks, one original about 1950s seized up, and a later one that is also oldish and again very stiff, as these are under the sink and not easy to get at, I thought of replacing them with a 15mm ball valve as these are far easier to turn off and also a Sure Stop remote switch unit as a secondary back up, this is because the flat may be let for a while, and it might save a disaster if it were obvious where the water can be shut off,
one problem, the flats have no obvious mains stop cock so will have to use a freezer unit on the flats incoming pipe, can anyone see any problems with this idea.
Thank you
Thank you
