In the next couple of weeks I will be replacing the existing Bath/Shwer Mixer Tap. Have spent a bit of time looking at the fitting of the existing mixer. A couple of questions I need answers to.
1. The existing connections show 22mm supply pipe to the hote water tap, but 15mm to the cold tap, is this normal?, I have looked at Screwfix item no, 13393 a Swirl Bath Mixer, it makes no comment on the connections.
2. The current connections are direct from the supply pipes to the tails of the hot and cold tap, I intend to change this connection to a flexible SS connection with a valve built in, using push fit, just a silly point, does the push fit end of the flexible pipe go direct onto the supply pipe and the washer screw end onto the tails.
Any advice much appreciated.
