Hi, I recently bought a house and the loft wiring was a complete nightmare. So I stripped it all out, and started again. I've wired in a new mains socket (for the train set ) which is fine. I'm struggling with the lighting though. I've tapped into the circuit with a junction box. I ran a cable from this to the 1st light fitting and then onto a second light fitting. Each light then has it's own switch wire and own switch. It dosen't work though. Do i need to return the supply to the junction box or is the problem with the switches? Many thanks.
