can anyone tell us if i replace my double oven i presume its hard wired, would i be able to use that circuit with the new single oven. i know if you have a single oven and want to replace it with double you need to hard wire the flex cable to supply but wot would you do vice versa. i say this because the current that the double uses is more i think wont that effect the single oven being higher rated circuit. any input would help. thanks in advance.
