I have a question about replacing dry rotted outside wall boards from the inside. On the outside corner of my master bedroom, the corner had been exposed to water damage and left to rot away after the previous owners simply sealed and installed vinyl siding, the leaking has appeared to have been sealed but the wood is dried out and crumbling away to the touch between two 2*4's at the corner starting about half way down the wall about 5 boards in total, the outside wall is covered in shingles then Styrofoam strapping then vinyl siding.
Could I get away with removing and rebuilding the wall with the two 2*4's inside and just put the wall back in place, or will I destroy the base for the vinyl siding. Please any help would be appreciated.
Thank you
Karl
Thank you
Karl
