I have a lintel as per the picture. It has expanded with rust and forced up the Gable above it.
I am replacing it with a new galvanised angle type under the outer leaf only.
I should remove 7/8 courses and rebuild to realign joints but I don't have time and was wondering if it was a crazy idea to prop it, remove the lintel and clean out the expanded joints and then lower the props a turn to settle the joints near to where they should be. Then I can simple repoint and replace the bricks needed to replace the lintel.
As you can see the whole panel of brickwork above is fine with no cracked joints so hence my desire to take the easy route.
