Repressurising Wocester Bosch 28CDi
21 Sep 2012
Essex
The repressurising knob no longer works, it has lost any grip to turn and open the valve (The Main key is still OK) Can I get this unit replaced or is there a way arounfd the problem. The pressure gauge is currently zero so I'm not using the central heating at the mment. Thanks
I think there is a small leak somewhere in piping. Usually gradual reduction in pressure, but not used Heating since April/May. Have had the system flushed\ with a sealant about 3 years ago by a plumber.
Sounds like leak that needs to be found if you have lost the pressure in about 5 months.
I agree about the leak, but also not sure if new boiler needed as well or can the repressurising unit be replaced ?
