Long time lurker, finally a question!
Having got inside the house sorted, now looking at the exterior. The house is a 70s built brick house, external walls a mix of decorative brick and rendered - roughcast above the DPC and plain finished render below.
At some point the render has been painted with some sort of coating - possibly because there is a touch of an effluoresence problem (tips on that welcome!) and had cracked in places, with some coming away. On taking off the loose render to repair, I discovered the loose stuff went below ground level. Dug down (About 2 brick depth) and some of the patches of loose/unfixed render go right down to where the render appears to stop (below is a mix of what appears to be loose rough cast in places and mainly a concrete mix).
So my question is, what do I put at the bottom? Do I just put the render on down to that level, or is any special treatment needed.
Also, should I treat the bare brickwork withanything prior to rendering (MY instinct says no because then the wall wouldn't breathe)
Thanks in advance
Dave
Thanks in advance
Dave
