reset button on control box needs pressed 1st every day
18 Jan 2010
hello...I have a bentone oil burner. its 6 - 7 years old. problem is, when i turn the heating on first thing in the morning nothing happens until i go out and press the reset button on the control box, everything works fine after this. ive changed the thermostat and the control box but nothings changed. its only for the first fire up this happens.....same when on timer. head is tortured having to press reset every morning...any ideas????? :confused:
The boiler may just need a good old clean out.....the air in the flue is very dense at the moment, and maybe the purge just isn't enough to shift that dense, cold air.
Have you had the thing serviced recently, and does the burner purr smoothly when its going - or does it have the occasional hiccup?
John :)
John :)
Thanks for replying John. i serviced it just last year but i suppose there would be no harm doing it now again after this winter we're having. could run a bit smoother alright.would the solenoid valve be at fault at all? thanks again. :D
Hi shead
I always think its a good idea to take the baffles out of the boiler in a yearly basis, and give them a good scrape with a wire brush. It also gives you some clue as to how things have been burning...the soot shouldn't be oily and there are often some yellow sulphur deposits.
Also vacuum out the fire box and study the gas path as it heads for the chimney so you don't miss any heaps of soot etc.
Certainly it is not unknown for the coil on the pump solenoid to fail - usually though they fail completely, and no oil flows at all - or they fail due to heat after 15 mins or so. Therefore I wouldn't expect this.
Its also necessary to keep the photocell clean.
To properly get things sorted you need to set the pump pressure, ideally replace the nozzle to rule that out and finally do a flue gas analysis when its burning well.
John :)
Hi shead
John :)
100% John thanks very much...ill get that done and let you know the result sure...much appreciated. :p
You're very welcome...post some more info about the boiler / burner and I'll see if I've got pump pressures, CO2 readings etc.
John :)
