I want to restore a chimney flue which was broken into in the first floor bedroom where a chest of drawers had been inset into the chimney breast. My initial thought was to use a good quality brick, but a friend has suggested using thermalite blocks for a quicker and easier job. Can I rely on these to keep the flue intact?
I will be putting a multistove in the downstairs living room so at the point where the flue is restored upstairs, it will have the usual output from a stove flue, but there will be no direct heat from the upstairs fireplace which I also intend to brick up. Bearing in mind I have no building experience.
Thank you
Thank you
