Reverting gas fire back to open fireplace
17 May 2013
Our Victorian house has fireplaces in nearly every room, it's unclear if they're original but are period (the ones in the reception rooms seem quite small).
In the main living room, the working fireplace was fitted with a gas fire. We want to return to an open fire. Is it likely the flue will have been left untouched when this was done and therefore since an authentic grate and fireplace is there, we could just lay a fire in it (other than the gas pipe obviously)?
Since the flue is already in use, would the building regulations about new flues/liners apply, strictly speaking?
The fireplace seems to have some damp issues (https://www.diynot.com/diy/bookmarks/?type=post&id=3921636) so would having it lit be helpful to dry it out?
I would think you would at least be best to have the gas pipe disconnected at source & have the chimney swept, which would show if the flue is clear & has enough updraft (sweeps have to use smoke bombs to be able to certify their work nowadays). Might be best to ask in building regs section for advice on the liner, but I know you would need one for a stove of any type.
The gas fire seems to indicate a good draft but yes it would get swept as a matter of course - who knows what birds might be up there!
If the thing had been capped I'm certain you have to follow the regs but I was hoping I could sneak this through... the benefit of the old-school flue is it heats the room above right?
Taking the gas pipe away would be sensible but people did use to have "gas pokers" so theoretically a metal gas pipe is not in itself dangerous, only one that leaks is. The bits that would get hot from a fire already get hot in a gas fire so again theoretically, setting a real fire without removing anything wouldn't go bang (I won't be trying it).
I couldn't see a sub-forum for fires and things... do they have a natural home or does it depend on the question?
