Hi
Would appreciate some answers to some questions I have. I am rewiring my kitchen
1. How high above the work surface do the socket have to be ? mine are 45mm.
2. The cable behind the work units can I just clip them to the wall or do they need to be in conduit. All cable will be run within the zones.
3. I want to put another double socket in the conservatory there is already one out there on the main house ring main but I can’t spur off of this one. Can I spur off the kitchen ring and if so how long can the cable run be ? I could include it in the kitchen ring if that is better. Also the cable will be going though the cavity wall to get out to the conservatory so do I need to protect it ?
4. I am going to put a 20A DP switch in the ring main above the work surface to supply a switched double socket below the work surface. I am planning to plug a Dish washer and washing machine into this will that be ok ?
