hi i have a combi boiler but my wireless thermo does not work i have to do it manually,is there smthing i can do or do i leave it up to the experts,any help would b good cheers!
If its built into the boiler you should use a gas engineer, if it is external the transmitter and receivers are on back plates that anyone can swop with the power off. If its build in consider changing to external controls as they are generally a lot cheaper.
Certain brands can be quite problematic what with 'forgetting' their pairing. I seem to find anything Salus branded is cheap tat. Older drayton units can fail to communicate and need replacing.
